Impeller reminder
- SunsetSteve
- Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing) - Location: Gananoque
- Has thanked: 30 times
- Been thanked: 19 times
Re: Impeller reminder
Follow up - we did remove plenty of bits and pieces and I hope these represent all that was in there. All water seems to be flowIng well. Spare gasket/O-ring not required so saving for another day.
- HudsonRiver01
- Vessel Info: 1990 Carver Santego 38
- Has thanked: 14 times
Yikes, I wouldn't have even thought of that. Makes me think now. I figured the ports were large enough to let them pass through. I'll be checking my impellers this week!
- Cooler
- Has thanked: 68 times
- Been thanked: 414 times
Yep, Viper is right on the button as always. You gotta find those pieces. They did not make it through the screens, so any water that does flow will just cavitate and eventually may boil. Back flush the water hose from the t-stat housing to the exit port of the water pump. Run into a pail, and there will be rubber pieces. Do it several times, and then when you reconnect, fill that hose with water before you attach to t-stat housing.
er
