Re: New Member - First Carver '07 35 SS
Posted: August 28th, 2021, 3:27 pm
danclev wrote:Qr BbpostHelmsman wrote:Qr Bbpost I owned a 2006 33 SS for 4 years which is the very same boat. They changed it to a 35 SS in 2007. What Does it have, crusader 6.0 engines? If so I can walk you through changing the impellers. Easy job but I would definitely change them. I would also change the belts. I have the props (they are brand new 22x22 1.5” shaft). Sold the boat a few months after buying them as spares. Anyway, pm me and we can go through the boat a little so you feel comfortable with it. I will also be glad to have a phone conversation with you. Carver pulled the manuals a month ago. I may or may not have pdf copies I will look for, for you
Thanks! That would be great. Yes, Crusader 6.0's. First question is how to ID the right impellers and buy them. I'll dig into that. I did find the owner's guide for the 36 which is essentially the same boat I'm assuming.
I cant attach a pdf. Pm with an email, and I will send you the Crusader Owners operation and Maintenance manual. It is for 2006 and 2007. A diagram of where the impeller is for the 6.0 is on page 58, and the part numbers are on either 68 or 69 depending upon whether you have a returnless fuel system, or an FCC fuel system. I have pasted and copied from those two pages below. It is very likely that you have the returnless version which can be verified by comparing your fuel water separator to a parts picture on an ordering web site.
ON-BOARD PARTS KIT 6.0L MPI
RETURNLESS FUEL SYSTEM - ‘05 To Present RK173092A-05
Box, On-Board (1) 22433
Belt, Serpentine (1) R066027
Fuse, 20 Amp (3) R153017B
Relay, 12V, Fuel Pump, Ignition, Start (1) R130011A
SparkPlug, Set, (Platinum) (1) RP030011
Impeller Kit, Raw Water Pump (1) RP061022
Primary Fuel Filter Element, 150 Micron (1) RP077014
Filter Element, Racor Fuel/Water Separator (1) 47047
FCC FUEL SYSTEM - ‘05 To Present RK173092-05
Filter and O-Ring, Kit, FCC (1) RP080026
