Page 2 of 2
Re: Water lines
Posted: September 27th, 2021, 9:10 am
Midnightsun wrote:QR_BBPOST Nothing wrong with lake water intake as long as you are in fresh water. The last 3 boats I had were lake water drawn from the factory and most are in my area. Never heard of an issue. I believe the only boats that draw from the potable water tank are those set up for salt water use as in equipped with heat exchangers.
I think it depends on where you're at in the fresh water. If you are in a smaller lake or one that gets warm, then algae can definitely be an issue. If you're in a cooler lake or on/near a river one that flows and prevents the growth of algae then it might not be much of an issue. A lot of the marinas around us it can make a difference if you're near the entrance to the marina (close to the lake) or in the back where there's more stagnant waters.
Re: Water lines
Posted: September 29th, 2021, 5:52 pm
by vineyardgray
This looks like a compelling system for treating raw water and the lines to/from the toilet:
https://www.gobius.se/en/produkt-kategori/seasmart-en/
