Gas smell coming from gas caps
Re: Gas smell coming from gas caps
My canvas has a rubber tube gasket stitched to the bottom of all the panels that come in contact with the glass. I can't see daylight through the bottom of my panels which really helps keep those areas water and insect tight. If they used that in their modification along with a couple of snaps in the right place, you should be able to prevent most of the water from getting in. You could also glue a piece of white plastic moulding on the horizontal surface under the deck fill on an angle to divert any water overboard that runs down there. A lot of guys do this around transitional areas like that to keep water off the floor/carpet.
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 211 times
Same caps, can say that we never smelt fumes comes from them. Since now the boat is put away, I'll be checking for this next season for sure. Nice insight.
