95 Carver Mariner 330
Cooperlogan
Vessel Info: 1995 Carver Mariner 330
twin 270hp
Re: 95 Carver Mariner 330
Post by Cooperlogan »
I changed the fuel pump this weekend took it out for a ride And it was great for about an hour and then started losing our PM again And shutting down just like before Since it was cooler out it appears that it has to get hot 1st and then once it gets hot it keeps doing it constantly
Anyone have any distributor problems that would be connected to this
Been thanked: 414 times
Post by Cooler »
Yep. that is where the valve system is located. I never have switched tanks, but according to the layout, it can be done. Here is another way you can get more detailed info. There was a small card issued to the original owners directly from Crusader. That CM350 model number appears on that card, about the size of a standard credit card. OR, you can contact a Crusader dealer, give them your Serial numbers, and they can get that detail from Crusader. Good luck! 8-) er
