bud37 wrote:Qr Bbpostcpoint wrote:Qr Bbpost And why would air not go in constantly when I blow air in. Is the tank pressurized, is the pressure relief valve out side blocked? how to I clear that if so? Or I am thinking there is something that is in the intake valve that's not letting air back because it's blocked? Only way to see that is to obviously remove intake line. Any one done that, or anyone knows the part that I would need for 2000 carver 356 intake valve? I figure if I remove, mine as well put new one in?
The tanks are not pressurized as they are vented to atmosphere, assuming your tank vents are clear and not restricted.
Actually on the surface it seems like those anti-siphon valves are working but they should still be checked for debris and operation......basically just a one way valve depending on the maker....allows fuel out of the tank when there is suction on the engine side ( engine fuel pump running ), but if the line breaks or there is a leak with no suction the valve does not allow the fuel create a siphoning action and drain out to the bilge.
bud, not sure that's the case. because I was able to blow air through the hose all the way from engine side to tank without effort. so I though maybe I did not have anti-siphon valve. But then after first try I was not able to anymore. So definetly there is some issue with that valve. It must have been open position and i manage to blow air through it till it sat back down. than I was not able to after 2nd or 3rd try. So tomorrow I plan on removing the valve and check. I like to get a new one while I am on it, does anyone here know the part for 2000 carver 356 anti-siphon valve? n If I can't figure out, basically I will remove it tomorrow and check at west marine, hope they will have same. I am assuming these are standard part, sut the right size needed.
