Page 2 of 2
Re: Engine oil choice
Posted: January 26th, 2025, 1:56 pm
by Journey!
My 1993 Crusader 454’s owner’s engine manual recommends a straight weight 40W oil. I use Rotella. Anyone else?
Posted: January 26th, 2025, 4:19 pm
Welcome to the forum.....how many hours on your engines ?
Posted: January 27th, 2025, 1:08 pm
Using a multi-viscosity isn't going to matter. It won't get cold enough while you're using the boat for the "W" rating to be effective, nor necessary.
Posted: January 29th, 2025, 5:23 pm
by mjk1040
Rotella 40W is all I ever used in our Crusaders!
Posted: January 30th, 2025, 12:37 pm
by waybomb
I run Rotella but also add a can of the old GM EOC. It's very high in zddp.
I wiped the cams in the Cougar years ago when they started changing oil so it would not clog catalytic converters. They removed the zinc. I was running flat solid lifters. Wiped all the engines' cams. I bought a bunch of the original EOS and have a lot left over, so I use it in these old Crusaders.
