Need Help - Leaking Toilet
- Has thanked: 456 times
- Been thanked: 1671 times
Re: Need Help - Leaking Toilet
BTW, the Flair-it fittings you currently have I find are getting harder to come by. Not everyone carries them now so it's a good idea to replace with quick connects in areas you can access and are currently working close to. At the very least, look for those fittings now and get a few spares while you still can as there's no telling how easy they will be to source in the near future.
- tonyp444
- Has thanked: 48 times
- Been thanked: 10 times
- tonyp444
I think it will be a lot cleaner install with the solenoid in the engine compartment. Anything special I need to do with screwing it to the bulkhead? Am I good to drive a short stainless screw through that heat shield and into the bulkhead, like what was done for the water pump? I just get anxious making holes in something and don’t want to do anything stupid. The shower wall is directly behind the bulkhead so obviously any screws need to be pretty short.
- tonyp444
I was testing the main positive and negative wires (the big 4AWG) expecting them to be wired to the “MACERATOR TOILET” breaker on the DC panel. However, I was getting 12v even with all breakers turned off. The only way I could cut power to those wires was by turning off the battery switch. I’m certainly not an electrical expert but that doesn’t seem right that the wiring would be bypassing the panel. Am I missing something here? Maybe because the toilet required such large gauge wire, they wired it directly to the battery with an inline fuse? If that’s the case, I’m confused on what, if anything, is connected to the toilet switch on the breaker panel.
I’m thinking for the new toilet I’ll just start over fresh and rewire it. Hopefully the PO didn’t put something random on the toilet breaker.
- Been thanked: 1043 times
That would be similar to how many anchor winch configurations, where there are "high current" and "low current" circuits.
- tonyp444
km1125 wrote:Source of the post What size (rating) is the "Macerator Toilet" breaker? Is it possible that's just for the control circuit(s), which would be a smaller overall draw, and the bulk of the power that's on the 4GA wires goes directly to the battery switch (via a larger current-protection device)?
That makes sense, I’ll check the rating next chance I get. I bet you’re right that it was a “high current” and “low current” with the two smaller wires being low. The weird thing is, based on the wiring diagram in the owners manual, there wasn’t a separate circuit for the controls, it was just a solenoid relay between the motor and controls (i.e. there was no need to power anything on a separate circuit). So I’m confused on why there was a low current circuit wired to the panel if that’s what it is. I suppose it’s very possible it was wired differently than the diagram. I’ll pull the panel cover and do some more testing. Thank you!!
- tonyp444
Since there is no circuit on the toilet breaker, I think I just cap all 4 of the old wires and mark them as abandoned, and wire a brand new circuit to the toilet breaker. Is that the way to go?
- Has thanked: 579 times
- Been thanked: 1210 times
Now if you find the other end of the large cable wires, perhaps you could use them as a feed/ new circuit to a bus/panel in the toilet and put a breaker in there. Those cables will carry good loads and are already there.
Just an idea/ different view.
