Carver 355 sliding door - difficult to slide
Reelpriority
Vessel Info: Carver 356 Aft Cabin
1999
Miss Judy, Murrells Inlet, SC
Been thanked: 4 times
Re: Carver 355 sliding door - difficult to slide
Post by Reelpriority »
The spray lubricant does not track into the cabin. I used it on a previous Carver which also had a rough sliding door. The product works and is certainly a much lower cost alternative to rebuilding the door tracks.
MISS JUDY
Murrells Inlet, SC
Jrr7885
Vessel Info: 1995 Carver390 cmy
Post by Jrr7885 »
I have the same problem with the sliding door for years I just found a spray at menards called Blaster dry lube with Teflon I was also missing a screw and nut on the bottom replaced it and the door now can be slid now with 1 finger and it is dry lube and doesn’t track in the cabin wish I tried this years ago but it works great now
Post by tomschauer »
Clean, clean, clean the tracks!!
Then use a dry silicone or teflon lubricant sparingly.
I've found the key is to keep the tracks clean. All dust and dirt seems to find its way in there. If you use to much or the wrong lubricant, it just traps more dirt and makes it worse very quickly.
uchu
Vessel Info: 1988 Carver Santego 2767 - Twin Mercruisers 4.3LX with Alpha-One drives
Has thanked: 86 times
Been thanked: 15 times
Post by uchu »
tomschauer wrote:QR_BBPOST Clean, clean, clean the tracks!!
^^This^^. Cleaning is step one. Then I used 3 in1 silicone spray and no problems afterwards.
