Crusader won't break 2100 RPM's
- waybomb
- CYO Moderator
- Has thanked: 53 times
- Been thanked: 426 times
Re: Crusader won't break 2100 RPM's
Topic author - Scurvy Dog
- Vessel Info: 1978 Santa Cruz 2866
Moosehead Lake, Maine - Been thanked: 1 time
But here's my follow-up question before I tackle the above... How do I know what "normal" is? I don't know how many RPMs I should expect at WOT at idle or under way, or how many kts to expect for cruising or WOT. I found some original Carver brochures which claim cruising at 16kts and top 22kts, but that's with twin gas 230's. I have a single gas 270. Not sure what this should do for a 7600lb boat with a modified-V.
Any guesses from experience and/or common sense?
- Seif911
- Captain
- Vessel Info: 1977 Carver Mariner 33'
- Been thanked: 4 times
Max RPM's are anywheres from 4000 to maybe 4600 at an average. With your boat being old like mine, I'd just keep it cruising.
There is also the prop that can really change the RPM's too but I am assuming that your previous owner did not play around with that (that I could be totally wrong).
I too am having a few issues with my engines. My port side would not go above 3200 last year. I rebuilt the carbs and retimed the engine. I just blew a freeze plug and spent all day fixing it because it was under the engine mount. Now I am hoping to get the boat in the water next week to see how my improvements work. Who knows?
Good luck with yours and let us know what you did.
Thanks,
Steve
Steve
