2000 carver 356 aft cabin batteries
- feeez
- Has thanked: 52 times
- Been thanked: 65 times
Re: 2000 carver 356 aft cabin batteries
F
- Has thanked: 458 times
- Been thanked: 1699 times
mjk1040 wrote:Source of the post.......There are like only 3 battery manufacturers any more and they just change labels for branding....
There are very few manufacturers, and each supplies for different brands however not every brand gets the same build. The manufacturers have several different builds for a given price point. The same manufacturer will produce a $200 start battery for one brand and a $50 start battery of the same spec for another brand. While they're both the same spec, the $50 build is nowhere near the quality of the $200 build. Branding and buying power accounts for something in the list price but the materials used is what you're really paying for.
- cpoint
- Has thanked: 208 times
- Been thanked: 27 times
- Been thanked: 622 times
- mjk1040
- Been thanked: 243 times
My strategy when buying batteries is to buy the best you can afford. When I say that, consider that if you are the type of boater that spends a lot of time on the hook, your battery budget should be one of the things at the top of your boating budget given that so much depends on power consumption and available power when you do any real boating away from a dock. Having said that, I would not spend large cash on batteries unless you have a good smart battery charger or you're just throwing money out the window, unless you exercize charging management with an old charger; such as not leaving it on during the week, and checking fluids often. Not leaving the charger on during the week is not a good idea for safety reasons though, hence replacment is recommended as smart chargers can be left on.
I don't like multi-purpose batteries. They are a compromize at best between a good start battery and a good deep cycle battery. You can't have the best of both in one as the builds/hardware required are different. If you have no choice but to use these, it's an indication that the DC electrical design is sub par otherwise the system would allow for proper battery design to be used given the intended load such as start batteries for engine banks and deep cycle batteries for house banks/loads. Do you have a battery selector switch; "1, 2, ALL"?
- cpoint
- cpoint
The bilge pumps should remain operational with the battery switch in the off position. To test, turn the battery switch off and operate the pumps manually from the helm, you should have pump switches there or simply go to one of the floats in the bilge and lift it with your finger, it should activate the pump next to it. To check if the CO detectors are wired the same, turn the battery switch off and the detectors should have a test button on them that you can push and hold for a few seconds. If they work, an alarm will sound. Try this first before you shut the batteries off though to ensure are actually working.
With your setup, I would always use the same bank for starting the engines and always the other bank to run house loads. Typically 1 is the start bank and 2 is the house bank but no guaranties this is still the case. With all the same batteries in your case, it may not matter much but use the same position every time for the different loads. If there are more batteries in one bank than other, use that bank for your house loads. When at shore, leave the switch switched to the house bank, not on both. Label the switch once you find out what 1 and 2 are, it makes it easier than trying to remember.
- cpoint
I will test the bilge pumps with power off as you suggest.
In regards to leaving it on 2 while at shore, will that still charge all batteries? or only ones under 2? As far as battery capacity, can I tell by looking at the gauges at the helm. Also while at shore, will it still charge if I have switch positioned to OFF? What I was planning on doing was to leave the battery switch OFF at dock, hoping that would charge the batteries still, and if power goes of only bilge pumps would be available.
Or I can leave it on and turn off refrigerator (during winter), because I wont be using it at that time anyway. If that's the case, if I shut off the DC panel completely, leave batteries on BOTH while at dock, would that be best? that way there will be no load on batteries, it will be on shore power, should power fail, BOTH batteries will take over, and only load will be bilge pumps should they be needed, is this correct thinking?
