Engines won't start!!! Batteries?
- Has thanked: 458 times
- Been thanked: 1699 times
Re: Engines won't start!!! Batteries?
- Has thanked: 585 times
- Been thanked: 1232 times
After rereading all this ,it appears you have one good new battery...if so, can you just put that battery in where one of the others is and try to start with that known good battery.....just put the battery switch in the position for that good battery.....if those others were submerged at any point they are scrap.....batteries are fairly cheap in the scheme of things.....you most definitely need known good ones to see what is going on for sure.
- Has thanked: 324 times
- Been thanked: 595 times
Disconnect all of the cables, grounds first, take a bit of sandpaper to the battery posts and the cable connectors until they are clean and shiny. Reconnect positive first and firmly tighten all connections.
Poor or dirty connections can pass voltage but fail to pass the amperage required to turn a motor over.
- mjk1040
- Been thanked: 243 times
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
I replaced the cable and all was fine after that. Apparently the corrosion was blocking any electrical current. May not be your problem but worth a look if nothing else is found.
- Been thanked: 1055 times
- Has thanked: 55 times
- Been thanked: 18 times
RGrew176 wrote:Source of the post
Also, when checking connections, don't forget the battery ground connections on the engine(s)
- RickieT
- Vessel Info: Carver 350 Mariner 1997
- Has thanked: 18 times
- Been thanked: 3 times
- Contact:
- RickieT
- Contact:
