Bottom Paint Sanding Option
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Re: Bottom Paint Sanding Option
Post by amanphoto »
km1125 wrote:Qr Bbpost
amanphoto wrote:Qr Bbpost Update: Wet sanding was not possible. The water is not yet turned on at the Marina. This makes it very hard to work on the boats that are stored there.
A few years ago I started working on the boat before the marina had turned the the water on. I brought out a utility sump pump and dropped it in the nearest marina well and plugged it in. The water was cold, but you have as much water as you need. I was very clean too because there wasn't any activity in the marina to stir up the silt. I washed and rinsed the whole boat down and it worked great!!
The water here is kind of gross.
Post by tomschauer »
I don't think I would want to "clean" my boat with that water!
