Was: Deck Core Thickness? NOW: Deck Replacement
- Been thanked: 1043 times
Re: Was: Deck Core Thickness? NOW: Deck Replacement
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
km1125 wrote:Source of the post I used a Fein oscillating cutter with a round toothed cutter to make those cuts. Makes a very thin cut and easily go around those corners.
I used a Fein oscillating tool with a round toothed cutter to make those cuts. Makes a very thin cut and easily go around those corners. With the scraper attachment it's also easy to remove any balsa that's still epoxied to the bottom composite layer without risking a hole or gouge.
More pics of the deck core to come next week- but I was able to make progress on my new steps yesterday:
Ben in SC
- Cooler
- Has thanked: 68 times
- Been thanked: 390 times
- BenTen
I'm using General Finishes DTHP Oil Based Penetrating Wood Stain (Danish Teak) and General Finishes Outdoor Oil (Clear), one coat of stain and 5 coats of clear.
Ben in SC
- Cooler
- waybomb
- CYO Moderator
- Has thanked: 53 times
- Been thanked: 426 times
Took them all apart, bought some TeKa cleaner, got rid of the grey, then sanded and sanded and sanded, got them nice and smooth, then took my time with Sikkens, and sanding between coats.
Been 5 years now, and still look as good as the day I reinstalled them
- BenTen
My boat, when I received it, only had steps on the starboard side so one of the most important projects to the Admiral was to rectify that situation to ease access to the upper deck and cockpit!
Ben in SC
- BenTen
New Core being fitted:
Top skins prepped and reinstalled:
Side Deck out:
And finally side deck back in:
I will now begin the process of sanding the edges, fiber glassing over the seams left from the cuts, and then fairing, top coating and new non-skid all over. At this point I feel that the work is about half done but it feels good to have solid deck under foot again!
Ben in SC
- tgmkwill
- Vessel Info: 1997 355 Carver Aft
- Has thanked: 1 time
- Been thanked: 3 times
Looks like on the bow sections you feathered the edges before reinstalling the skins, but didn't on the side deck. Any particular reason? Also, how would you feather the remaining deck to match?
Users browsing this forum: No registered users and 131 guests
