Page 3 of 3
Re: Add engine access panels to floor
Posted: May 1st, 2019, 6:00 pm
by mjk1040
That definitely is one big power plant. Hope there's an answer to your question that doesn't involve cutting!
Posted: May 1st, 2019, 8:33 pm
by Midnightsun
Have you called Carver by any chance? I did when I had questions about the boat before purchase. I happened to get a hold of one guy that worked on the boat during assembly, he knew every nook and cranny. Definitely call if you have not done so already.
Posted: May 2nd, 2019, 12:21 pm
No easy way around this if there's little clearance above the engine unfortunitely. There has to be enough room for the cover to clear the cam and valve train. I assume they'll check/adjust the injector rockers at the same time?
