Re: Pink Stuff Facts
Posted: October 18th, 2019, 9:16 am
I keep seeing folks refer to "corrosion inhibitors" when referring to the various concentrations of propylene glycol and even saying that some of the higher freeze points have more.
I DO NOT believe this is the case. I researched many of the various winterizing solutions and none of the prop glycol products had ANYTHING except prop glycol and water. The lower freeze points have a higher concentration of prop glycol but that's about it. If they are "non toxic" they don't have any "corrosion inhibitors" added in. Just putting in prop glycol by itself IS a "corrosion inhibitor" because you're displacing the air or pure water that would be up against your metal.
This does **not** apply to some automotive prop glycol products, because they are formulated for a different use. They are also likely *NOT* completely "non-toxic", but significantly less toxic than the old green antifreeze, especially for pets.
Ask for the MSDS sheets for the products and you can see for yourself.
(the alcohol-based products ARE somewhat 'toxic' (corrosive) to ANY system that contains metals)
