Ok, you need to walk away from this boat...and don't look back.
Next boat you find, get it surveyed. If the seller balks, walk away.
I'd bet money the seller knew these issues you found and was hoping someone would buy the boat and not find out until money change hands.
New "powerboater" joining (Montego 25)
Re: New "powerboater" joining (Montego 25)
Sounds like a scary DIY mess.
Move on. I believe this one may be endless headaches and may cause loss of cash itis.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
There are to many things that just don't add up for that boat. Personally I would walk away.
- dodgingwrenches
- Vessel Info: 1990 Carver Montego 2557
- Has thanked: 2 times
Honestly I don't think the seller even knows. He bought it this spring and it was his first boat. He just didn't know what to look for and didn't get a survey either (and now is buying a bigger boat). A lot of this stuff I had forgotten about since it has been a few years since I owned a boat, but some of it is new to me too (my boat didn't have A/C...)
- dodgingwrenches
I just want to thank everyone for the input - it has been very helpful!
This vessel sounds like it has/had an owner that made very questionable modifications. The items you listed are just what you could see at this time, I suspect you'd find several more during ownership. Bottom looks good though, but that's just a cosmetic coat of paint to make it look pretty for the prospective buyer. The big question, and what really matters are the vessel's bones, the condition of the systems within, and the way in which things have been repaired and maintained.
You need to approach this without emotion as that often leads to purchasing something that will cost you big bucks later. I'd recommend walking away. I know there is limited inventory but don't be rushed into buying something because of that, there will be others.
Good luck with your search.
Really?! Wow, that's quite a statement. I've been around boats most of my life and have been repairing them on a professional level for decades, but I would never say that I am as good as any surveyor. It's a different trade requiring very specific training. Remember, you don't know what you don't know, and what you don't know is what can come back to haunt you later.dodgingwrenches wrote:QR_BBPOST.....Anyway brought a friend who is as good as any surveyor.....
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
I'm no expert, but 99.9% sure an inboard powered boat is ABYC required to have a working blower. If anything had happened to this boat and your insurance company could even remotely connect it to lack of a blower, I can see them denying your claim.dodgingwrenches wrote:QR_BBPOSTbuster53 wrote:QR_BBPOST AC hooked up to shore water...that would probably get you kicked out of our marina...or at the least, one warning to fix it immediately. Yes, it will be expensive...haul the boat to install a thru hull, purchase a thru hull and water pump and hook up all the plumbing connections and run wiring to run the pump. Easily will run you $1000.
Forgot to add, another oddity is we couldn't find a blower switch anywhere? Saw the hoses for a blower and think all gas engines need one, but didn't find a switch and didn't hear one come on either. And the aft bilge had some water in it, but the aft bilge pump switch was repurposed for something else, so not even sure there was a switch to manually control it or check if it worked
Had the boat been surveyed, this issue probably would have been the #1 critical deficiency that demanded immediate action.
