Gas tank leak
- Matt1989Carver3807
- Has thanked: 13 times
- Been thanked: 3 times
Re: Gas tank leak
The end of the tank appears to have some contour but I think "it is probably safe to assume the bottom of the tank is flat". I think that "it is probably safe to assume the fuel pickup tube is about 1/2" above the floor of the tank.
Based on these assumptions, is anyone aware of a liquid material which could be poured into the tank (like epoxy) and form a gas proof liner?? It might take several gallons to get above the level of the leak.
Further, one would have to fabricate and install another fuel pickup tube which would extend to 1/2" above the level of the "liner". This might be able to be inserted through a hole drilled in the deck as is the fuel fill hole. Would appreciate comments/suggestions.
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Gas tank leak
There are services that spray the inside of tanks, don't know how successful that is but I know a few access holes have to be drilled to get into each section between the baffles in the tank. I know of someone that had it done but it was simply a measure to dump the boat on someone else. The evidence of a problem was pretty obvious though and ended up costing him money in the sale anyway. He ended up settling for what could easily have been the cost of a tank replacement.
For what it's worth, I've played a part in only one tank removal through the side of the hull. This was due to the boat's construction and lack of access from above to remove the engine. The rest were replaced by removing the engine with an A frame and resting the engine on the floor above the other one. Ya it's work but not that bad and totally doable. Can't even see it taking much longer than glassing in the side of the hull again, that comes with its own set of preparations and challenges.
- MajorV
- Vessel Info: 1992 Carver 33 aft cabin
Twin 454 Crusaders
"Easy Feelings"
The Landing at Ivy Lea
Ivy Lea, Ontario - Location: 1000 Islands
- Has thanked: 11 times
Re: Gas tank leak
- V12diablo
- Vessel Info: 2001 Carver 356 Aft Cabin
- Has thanked: 1 time
- Been thanked: 13 times
Re: Gas tank leak
I know we have used fuel bladders in aviation and racing for years. They could be built to fit the inside of the existing tank if you have enough access to cut in a opening to install it. Just a thought.
Jason
Re: Gas tank leak
Re: Gas tank leak
Re: Gas tank leak
I think perhaps the best overall solution to the leaking tank problem may very well be to remove the port tank and design a smaller tank which can be fitted into the port tank space. This would allow for some ballasting and provide an increase in range without having to remove the port engine. It might be possible to replace the 140 gallon tank with perhaps a 70 or so gallon tank which would be significant.
The process would involve 1. removal of the port tank and perhaps some of the motor exhaust piping 2. construction of a custom configured (aluminum most likely) tank and 3. construction of the necessary fittings and strapping features. The end result should be satisfactory from about all of the considerations. After all, this is an older boat with somewhat limited cruising potential. What you think?
Addendum == My checking around indicates the preference for an aluminum tank because plastic high profile tanks bulge when filled with gas and are not constructed with baffles.
- RGrew176
- Vessel Info: 2022 Stingray 182 SC
- Has thanked: 72 times
- Been thanked: 467 times
Re: Gas tank leak
Re: Gas tank leak
- RGrew176
Re: Gas tank leak
Users browsing this forum: No registered users and 76 guests
