Nav Lights - Sidelights stopped working
Been thanked: 1055 times
Re: Nav Lights - Sidelights stopped working
Postby km1125 » June 5th, 2021, 9:36 am
Thanks for posting the follow up.
You'd still be well advised to change out all those push-on connections with screw-down terminal blocks. The hardest part of that whole project was creating a mounting board and I went a little overboard to avoid using any screws that would show from the outside. You could easily mount a panel (starboard or wood) and screw it in from the backside and the screws would be still hidden under the seat cushions and you could use flathead screws so they would be flush with the fiberglass. Your lower helm has the same issue and I'd recommend the same modifications.
hinzee623
Vessel Info: 1986 Carver 3607 Aft Cabin
Has thanked: 5 times
Postby hinzee623 » June 7th, 2021, 8:44 am
km1125 wrote:Source of the post Thanks for posting the follow up.
Noted...Thank you for the advice!
CaptDenny
Vessel Info: 1998 Carver 405
Been thanked: 2 times
Postby CaptDenny » June 7th, 2021, 10:28 am
Maybe a silly question BUT you said that the ON/OFF switch is at your navigation station.
My 405 has the same BUT also has a breaker marked NAV LIGHTS at my main panel down by the gally. Do you have this?
GOOD LUCK
Postby km1125 » June 7th, 2021, 10:34 am
The 3607 does have a breaker for the nav lights, but it would provide power to the mast and stern lights as well as the sidelights. The switches at both helms are a three position switch, with up being 'nav', down being 'anchor' and the middle is off.
Users browsing this forum: Google [Bot] and 28 guests
