Most economical cruising speed
kgarguilo
Vessel Info: 1999 Carver 406
Has thanked: 197 times
Been thanked: 55 times
Re: Most economical cruising speed
Post by kgarguilo »
[/quote]
km1125, that is a cool graph, what program generated it?
Kevin G.
1999 Carver 406
kgarguilo wrote:Qr Bbpost
Just MS Excel. I just added a calc for MPG based on the other numbers.
karenunger615
Vessel Info: Have owned two Carvers of our four boats -- and they were my favorite. Best use of space, comfortable and easy to handle. Had major issue with a 42 several years ago that required pulling an engine and replacing the pan underneath it. Carver really stepped up to help. We've been boatless for a while now, and are considering "diving" in again - hopefully to try the Great Circle. Found this Forum and already learned some things. Thanks for being here.
Has thanked: 4 times
Post by karenunger615 »
Would like to see this graph, if possible.
Karen
MyPleasure
Vessel Info: 1992 Carver 36 aft cabin with Volvo 740b engines. Westerbeke 5kw generator. Bought the boat in Portland Oregon in June, and a friend and I brought it up to Sidney, BC. Great trip!
Been thanked: 23 times
Post by MyPleasure »
Wow, we got a little off topic, but all information is valuable that’s for sure. I found that the big blocks are sure more fuel hungry than the small blocks that’s for sure! We love our 36 Carver aft cabin, but we should have kept our 4207 with the 375hp Cats.
We we’re just on our friend’s 3488 Bayliner for happy hour, and the Bayliner has no room on it compared to our 36 Carver. Carver may not be in a class like an OA or a GB, but we love them! They are so comfortable and roomy compared to just about any other make of boat, I will stick to Carver anytime, no matter what that David guy says!
Al
1st Carver 1987 32 Aft Cabin
3rd Carver 1995 350 Voyager
MyPleasure
Hey Bud37, yes they are definitely the marine version Edelbrock carb, should be for the price! The exact same model as the port engine. It has worked out very nicely compared to the old Holley that came from the factory.
Al
MyPleasure
We just got back from our favourite anchorage yesterday, and I did find quite a difference in fuel consumption this trip.
It’s about 10 nautical miles to the anchorage, but last trip we averaged about 1,800 RPM with gave us 8 1/2 - 9 knots, this trip we cruised at 1,500 RPM at 7 1/2 - 8 + knots. Just in the last trip, we saved almost $100 in fuel cost. That is of course planning our trips after the right tide change.
That old theory of travelling at or near hull speed gets the engines better fuel economy seems all right to me!
Al
MyPleasure
Hi KM 1125, does your 406 have big block gas engines? If so, are they the 496 Crusaders? You’re 406 gets better fuel mileage than our 3607 with the Volvo 454’s, that’s for sure. Maybe it’s because of the longer hull, and the better fuel injected engines.
At 1800 rpm, our engines use about 6 1/2 GPH each. We brought the boat up from Portland, Oregon, we ran at 2400 rpm up the coast, and my flowscans registered snout 12 gph for each engine. Of course I probably ran at the wrong rpm for fuel economy, but we had the trip planned at a certain speed, so economy went right out the window!
Al
MyPleasure wrote:Qr Bbpost Hi KM 1125, does your 406 have big block gas engines? If so, are they the 496 Crusaders? You’re 406 gets better fuel mileage than our 3607 with the Volvo 454’s, that’s for sure. Maybe it’s because of the longer hull, and the better fuel injected engines.
That's not my data. I just graphed kgarguilo's data he collected from his boat.
You really need to make sure the engine is running correctly before changing other things (like props). I wonder if your engines were running rich or have issues with ignition timing which would cause a loss of the rated power for the engine. It still could start and run really good, just consume a lot more fuel for the power that it produces.
If the carbs and ignition system are correct, then you won't get much more performance or economy just by going to fuel injection. You have to do a lot more changes and also have a lot more feedback from the engine to be able to reliably generate more power with a given amount of fuel. Most marine engines (especially anything over 10 years old) don't have those capabilities, so those fuel injection and ignition systems can only result in very marginal improvements. They can't push the 'limits' of the block because a small thing wrong would lead to big problems quickly, so they need to be pretty conservative or they're reliability numbers tank.
MirrorFinishPolishin
Vessel Info: 2004 Carver 350 Mariner
Post by MirrorFinishPolishin »
Not sure how much this will help you as I don't have Big Blocks, but here is my fuel consumption on my 2004 Carver 350. I was playing with trim tabs, so even in the upper RPM there is trim tabs down a bit, so that part is a bit inefficient in this graph but it should be kind of close. There was also a lot of wind on this test with full tanks. Don't pay much attention to the first run that didn't go much over 4,000rpm as that was before changing wires, caps, rotors and plugs.
I'll be testing again soon and brining the trim tabs all the way up at higher RPM, but this is what I have for now. Fox marine data showed 68% throttle at the 4,350rpm and didn't want to go anymore with all of the wind and such on the initial tests. Will go out again to push it a bit more just to make sure everything is 100%.
Also important note...the MPG is multiplied by a factor of 10 everywhere to make it more graphical
Fusion Audio W/11 Speakers, Etc
Garmin W/Fox Marine, Etc
High Polished Anchor, Fender Holders, Railing, Trim, Etc
https://www.mirrorfinishpolishing.com
MyPleasure
Well, might have found out why the boat was using so much fuel, both distributers were completely rusted up and timing springs were gone.
Both distributers have been rebuilt by a very knowledgable fella and now should work properly.
A boat with twin big blocks is never going to be great on fuel, but anything to help is good!
Al
