Carver 3207 Revised - 2015 projects & bow thruster
Mkemper
Vessel Info: 86' carver 3207 Aft
[IMG]http://i1238.photobucket.com/albums/ff498/mjkkemper/null_zps98e8d64b.jpg[/IMG]
Been thanked: 8 times
Re: Carver 3207 Revised
Post by Mkemper »
Sliding in the modular units.
Installed the trim around the shelves. Have to cut the top piece yet. TV will go in the big section
Put a coat on the stairs. Trying to decied if I should put a non-skid additive or get some non-skid pads to put down when we a swimming
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Post by AaHubb »
Those shelves are going to be a nice addition and look great. I have found non-skid to be a real dirt collector, how about a towel for a temp door mat.
'99 404 CPMY
SeaDragon
Mkemper
Post by Mkemper »
I ran a chase from the one cabinet to the other. The back of the large cabinet is the case for the engine vent so I did not want any electrical in there as well as making sure the compartment is sealed
Ready for a finish!
Mkemper
Post by Mkemper »
Got late so the pictures are a little grainy
AaHubb
Post by AaHubb »
Wow, great job. That electrical chase is a good idea.
'99 404 CPMY
SeaDragon
Mkemper
Post by Mkemper »
I got the carpet installed
Hooked up the Batteries to see how the new panels light looked
Ready to go in this Wednesday
Been thanked: 492 times
Post by waybomb »
Looking good!
iceman3500
Vessel Info: 1987 Carver 3207
Post by iceman3500 »
Is that just one piece of carpet? If not, what did you do for the hatches? The cabinets turned out awesome. You mention you didn't want any electrical below decks. Would it be a problem wiring up a 12 volt car amp, etc under there? The wife will lose her mind if I bolt any electronics visible inside the salon. Thanks.
Mkemper
Post by Mkemper »
iceman3500 wrote:Is that just one piece of carpet? If not, what did you do for the hatches? The cabinets turned out awesome. You mention you didn't want any electrical below decks. Would it be a problem wiring up a 12 volt car amp, etc under there? The wife will lose her mind if I bolt any electronics visible inside the salon. Thanks.
Yes just one piece of carpet. You just need to roll it up to gain access to the hatch. In regarding the electrical what I meant was that behind the forward large section for the TV is the chase for the venting for the engines. I did not want to put a electrical outlet in that section that would protrude into this vent chase. So a ran a pvc pipe chase (with blk cap) through the electrical panel section to the other shelving section in which I have a plug.
Mkemper
Post by Mkemper »
Well I think it's time to enjoy the summer. Thought I'd finish up with some before and after shots.
Different boat but same setup
After
Green carpet just like you see in Brady bunch household
After
