SOLAR PANEL INSTALLATION
- madalinet
- Has thanked: 1 time
Re: SOLAR PANEL INSTALLATION
How did the installation go? I hope everything went smoothly. As for grounding the solar panel frames, it's a safety requirement. Grounding prevents the buildup of static electricity and reduces the risk of electric shock. You can ground the frames by attaching a grounding wire to each panel's mounting holes and running it to a grounding rod or the negative terminal of your battery bank. Don't skip this step, it's important! And hey, if you're ever in need of some solar system kits or accessories, check out this site I've used before: https://www.dragonsbreathsolar.co.uk/pr ... stem-kits/ . They've got some great stuff at reasonable prices.
