Thanks Viper, I keep it closer to 2-3 minutes of run time, with a careful hand on the glass portion of the exh system to make sure it's not getting too hot.Viper wrote:QR_BBPOSTBe careful here, it doesn't take long for the inside walls of your exhaust hoses to be destroyed when there's no water cooling them.390Express wrote:QR_BBPOST ....I have the impeller belt, and water pump belt off of it. I planned to start it and run it for 3-5 min. at a time, a couple times, before I launch.....
Walter V Drive Systems Gearbox Q
- 390Express
- Captain
- Has thanked: 141 times
- Been thanked: 15 times
Re: Walter V Drive Systems Gearbox Q
- Been thanked: 1792 times
Why not run it with water?? Then you can run it as long as you want.
- 390Express
- Captain
No damn water or electricity at its current location. Marina won't let me launch it until I know it runs. It has to at least power itself to the dock, then I can really start working on it. I have heavy equipment to pull anything that needs to be pulled at the dock. P.I.T.A.!
- Has thanked: 605 times
- Been thanked: 1314 times
Curious when you took that pan plug out....what all did you get out of the pan ?
- 390Express
- Captain
I drained it completely before pulling to pan plug. I got about another 2/3 - 3/4 of a quart out of the pan with the plug out. It really wasn't difficult at all. I kind of wish the factory would swap the dipstick from the middle to the outside, it would be a lot easier if the plug was located in the middle of the boat.
Because of the numerous ongoing projects this year, I likely won't mess with anything to do with oil drainage, but next year I will likely add a drain system. I'll probably add a T- at the elbow that has the dipstick, so I can do everything from the middle of the boat. A "T" fitting, shutoff valve, and some 3/8 brass piping, with a cap when not in use should make the job much easier, and drain more oil out of the system.
Heh there....just an FYI.....you may know but there is nothing Trojan about your boat cept the name, it is all Carver as far as I know....posted it here cause didn't want to misdirect the other thread......so it was all oil out the bottom of the pan , good stuff........
Here is something may help .its a 95 but, check it out.......
https://carveryachts.blob.core.windows. ... _95_v1.pdf
- 390Express
- Captain
Ha, yup, I'm aware. That's why I'm here, on the Carver forum.
I only post the "Trojan" info, so people know the model I have. I believe Carver also made an Express during the same time frame. 3566 or something of the like?
