Re: over heat
Posted: June 8th, 2022, 9:32 pm
Hans, so you are saying they work for a while and lose prime while under way? Very Odd.
Just something to check, I replaced my MerCruiser pump housings and impellers this year. The genuine MerCruiser pump kits came with new bolts and washers. While I was assembling the pumps, I noticed the bolts bottomed out before they actually sealed the impeller housing to the pump tightly. I was able to slide a .030 feeler gauge in between the pump and the impeller housing. Probably wouldn't have caught it if I did it on the boat, but I had them at home. Put the original washers back in (they were twice a thick as the new ones) and a nice tight seal. I am sure I would have had a problem if I installed them the way they were.
Hopefully you can find your gremlins soon!
