Re: Riviera bilge question
Posted: August 8th, 2021, 6:58 pm
Thank you - good idea. Anyone know of a good value hot water tank with the heat exchanger option?
Discuss Carver Boats and Yachts at the best Carver Owners Forum on the net!
https://www.carveryachtowners.com/
Back at it this weekend when temps will be lower and I'll have a buddy on board to assist. Will report back!so I had a beer and thought about it, then went back home.![]()
hcarmich wrote:Qr BbpostUncle Mike wrote:Qr Bbpost On my Riviera, there is also small amount of water in the fdw bilge, just enough water not to have the pump to start. The fwd pump is right there under the table. I will be at my boat tonight and provide photos if needed.
I haven't check for the fwd pump but the master one (mid bilge pump) is connected directly to the battery, no switch or breaker is needed.
I was lucky to get all the original documents and technical sheets (wiring plan, etc...) with my new to me Carver Riviera 1989, let me know if I can provide you information;)
Is it possible to get these from you? Would be helpful for sure! thanks
Hello Unc.,Uncle Mike wrote:QR_BBPOSTThey would need to be scanned... next I get to the boat I will see what I an do to share those diagrams;)hcarmich wrote:QR_BBPOSTIs it possible to get these from you? Would be helpful for sure! thanksUncle Mike wrote:QR_BBPOST On my Riviera, there is also small amount of water in the fdw bilge, just enough water not to have the pump to start. The fwd pump is right there under the table. I will be at my boat tonight and provide photos if needed.
