1989 3807 Where is the Generator Start Button
- justtls
- Has thanked: 6 times
Regards,
Terry
- Vessel Info: 1986 Carver 3227 Convertible
Re: 1989 3807 Where is the Generator Start Button
- justtls
eric_b wrote:The toggle you are looking at should also start the genset, it should be a 3 way toggle, stop/neutral/start. There will also be a toggle/button directly on the generator. What model genset does the boat have? Mine is an ONAN MCCK 6.5 gas genset.
Thanks for the info. Mine has the Koehler 7.5R . The only Switch I can find is the one on the main panel, its a two way toggle that just has off/Start, however I was reading something yesterday that would indicate that the the two way toggle switch may be the only one and that the Generator just stops the starter once the engine is started. I was looking for the remote control panel that is apparently an option because when I tried to use the start toggle nothing happened. I guess I will need to check the connections etc from the battery/Switch. Thanks again for your time.
Regards,
Terry
- Been thanked: 618 times
there is a switch on the genset that operates the same way if it wont start form either then time to check battery switch but you should at least here it trying if not then the relay the switches activate may need to be looked at
- justtls
- Has thanked: 457 times
- Been thanked: 1685 times
