1998 Carver 530 Voyager Pilothouse
Topic author - Scurvy Dog
- Vessel Info: 1998 Carver 530 Voyager Pilothouse
We are now broke and cannot afford to cruise anywhere! Just kidding. The boat yard is always very glad to see us.
This is a great boat. The last issue I have to address is water in the aft bilge area. I always have at least two inches of water that I do not know where it comes from. Does the water in the sink in the galley empty into the area between the two engines? I pumped water out this past weekend that was soapy. My wife had just finished cleaning dishes and I noticed the soapy water. Does anyone know about the water issue and the sink drain?
Thanks for the help. Catawba Tim
- Ramsport47
- Has thanked: 72 times
- Been thanked: 57 times
Re: 1998 Carver 530 Voyager Pilothouse
T-Merc 350 Mag MPI (300hp)
- Ramsport47
- Vessel Info: 2004 466 Carver
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Ramsport47
- voyagerfan
- Vessel Info: 2000 Carver Voyager 530
- Has thanked: 3 times
- Been thanked: 8 times
If you don't see water coming from that pipe then you may have a fitting on the aft end of the tank that is leaking. That is the situation I had. The discharge from the sump pump itself goes through the aft wall of the tank then takes a turn to port. On my boat it was the thru-tank fitting that was leaking into the bilge. The water finds its way through the hole in the stringer that separates the ER bilge area from the bilge area in the master SR. You must take the forward ER bilge pump loose and hold it up to see this hole.
Let me know what your investigation finds and I will elaborate on what you need to do if it turns out to be a leak from one of the sump tank fittings.
John
Satisfaction
Grafton, Il
- Thomas.gilfillan
- Vessel Info: 1998 530 Carver Pilothouse
Users browsing this forum: No registered users and 188 guests
