Salon A/C in Carver 370 Aft Cabin
Topic author
bwilson
Vessel Info: 1995 Carver 370 Aft Cabin
Postby bwilson » July 20th, 2015, 12:47 pm
Hey All,
I just discovered soaking carpet in the salon on the port side around the cabinet. I pulled the cover where the a/c unit sets and discovered alot of water in the drip/ condensation pan that I had to sponge out. I could not find blockage in the drain line. I am going to blow compressed air through the line.
Any idea what else could cause the back flow of standing water in the condensation pan?
Has thanked: 53 times
Been thanked: 426 times
Re: Salon A/C in Carver 370 Aft Cabin
Postby waybomb » July 20th, 2015, 6:17 pm
If it's in the pan, the drain must be plugged. Can you get to the drain hole ion the pan? Use very light pressure if trying to blow it out!
You might try a piece of 12ga stranded wire or an electrical fish tape if you have one.
Has thanked: 455 times
Been thanked: 1671 times
Postby Viper » July 20th, 2015, 7:53 pm
Check your sump too, it may not be pumping out and backing up through the condensate drain line.
Topic author
bwilson
Postby bwilson » July 20th, 2015, 10:03 pm
Thanks for the advice. I will check this out tomorrow
