Flybridge Throttles
- Terra Nova
- Vessel Info: 2002 Carver 410 Sports Sedan
- Has thanked: 2 times
Flybridge Throttles
I have a 1988 3207 Aft Cabin Carver. The Starboard throttle on my flybridge keeps slipping so I have to continuously hold it to keep it in position. Does anybody know if there is a way to adjust the cable to increase the tension? The flybridge is connected to the lower helm but I couldn't locate a connection point on those controls.
Re: Flybridge Throttles
There should be an adjustment screw on the throttle control itself to increase or decrease the amount of effort required to move it. You want a happy medium between tight enough so it doesn't spring back on you and loose enough that it can still be easily moved.
- Terra Nova
Perfect! Do you know where that screw would be? I still can't find it. Would it be on the lower helm or on the flybridge helm where the issue is?
- Chris86
- Vessel Info: 1986 ACMY 4207, Twin 454, with previous owner's self righteous modifications.
- Has thanked: 5 times
It should be on the sides of the throttle and shifter bodies around the arch of the lever housing.
- Terra Nova
Thanks - I will take a peek in the spring. Winter is coming up here in Canada
