Rudder Stuffing Box - 350 Mariner
TonyC
Vessel Info: 1998 Carver 350 Mariner
Has thanked: 22 times
Post by TonyC »
All,
The port rudder stuffing box started to leak this summer. I did tighten but only reduced but did not stop the leaking. Now in storage for the winter, I unscrewed the female end, pulled it up as far as possible and had difficulty seeing any signs of the stuffing. I did manage to get a pic (not great) and is attached. The white material appears to be what is left of the stuffing.
I plan to clean out whatever is in the housing and re-stuff. The Owners Manual indicates three rings of impregnated FTE 1/4" stuffing. Unable to find FTE but due to the age of the boat and new developments there must be updated types. Also, 1/4" seem a tad thick for the space provided.
Has anyone changed the stuffing on their rudders? Does the above sound correct? Suggestions?
Thanks,
TonyC
SanJuanDreamer
Vessel Info: Still Searching
Been thanked: 21 times
Re: Rudder Stuffing Box - 350 Mariner
Post by SanJuanDreamer »
I used gortex, whatever size was called for, did it some time ago.
Post by mjk1040 »
Tony; Hopefully Viper will chime in on this, there are multiple types of packing out there, I believe there is a PTE type now. At least u know the size, does it tell u how many rings of material to put in? May I suggest while u r at it to repack the other one too. Mike
TonyC
Post by TonyC »
mjk1040 wrote:Tony; Hopefully Viper will chime in on this, there are multiple types of packing out there, I believe there is a PTE type now. At least u know the size, does it tell u how many rings of material to put in? May I suggest while u r at it to repack the other one too. Mike
Hi Mike,
Yes, the diagram shows three rings per side. I do plan to replace both sides this winter. Thanks for the reply.
TonyC
TonyC
Post by TonyC »
SanJuanDreamer wrote:Qr Bbpost I used gortex, whatever size was called for, did it some time ago.
Do you recall if it was 1/4"?
SanJuanDreamer
I'll take a look at my manuals...that's probably where I found the size and lay-out.
jcoll
Has thanked: 18 times
Been thanked: 18 times
Post by jcoll »
Just got done doing mine on a 355 Aftcabin. The parts manual indicated 1/4" material. I'd say it's a pretty safe bet that your Mariner is the same.
TonyC
Post by TonyC »
jcoll wrote:Qr Bbpost Just got done doing mine on a 355 Aftcabin. The parts manual indicated 1/4" material. I'd say it's a pretty safe bet that your Mariner is the same.
Thanks, jcoll. Unless I hear otherwise, will go with 1/4". Do you recall the type of material used?
TonyC
TonyC wrote:.... Do you recall the type of material used?...
Chances are it's standard flax packing. For rudders, I wouldn't stress too much about using more exotic materials.
TonyC
Post by TonyC »
Viper wrote:Qr Bbpost
Agree Viper. Friction is significantly less at the rudder than at the drive shaft. Thanks.
