Was doing a systems check on the new boat and could not get stove/oven to work. AC stove breaker "on". LPG tank valve "open (pressure reading 100). Previous owner said solenoid needed replacing.... therefore bought and installed new one.
Problem? The stove panel next to stove is not getting power (light not lighting up when switched to "on position"? I see there is a fuse next to light, could that be the issue? not familiar with these types of fuses.
Any Ideals?
Princess 3 burner Propane stove/oven
- Flinty
- Vessel Info: 1995 CARVER 390 CMY, Twin CUMMINS
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Princess 3 burner Propane stove/oven
If I understand your question you need to check the LPG breaker in the 12 volt panel not the AC panel. I don't remember a fuse on the LPG control panel in the galley. A picture would help.
..Aaron
..Aaron
'99 404 CPMY
SeaDragon
SeaDragon
- Flinty
AaHubB,
not the best picture, but the black panel below sink is labeled Propane panel, which contains an on/off switch and the small white square is labeled fuse? there is also an illumination light which lights up ( i assume) when the system is charged. will check the 12 volt panel as well. Thank You for suggestion.
- Flinty
Aahubb reviewing your suggestion, I believe the breaker associated with the A/C power labeled "Stove" would be for an Electric stove option (not a propane one which i have) therefore your right........ concentrate on the 12V supply.
- AaHubb
Yup, I have that same panel and it does run off the 12v supply. I probably have the fuse too just never had a problem with it.
..Aaron
..Aaron
'99 404 CPMY
SeaDragon
SeaDragon
