Page 1 of 2
Potable water tank monitor meter??
Posted: May 5th, 2017, 7:57 am
by dsolo
Need help locating the meter for the potable water tank. Documents says the boat has one, I see the wiring coming from the water tank, just can't find the meter? Help again!
Dan
Re: Potable water tank monitor meter??
Posted: May 5th, 2017, 8:41 am
by justavacation
Hi, I have a 2000 406 and my water tank monitor is in the rear head next to the light/fan/head switches. Just under the counter top.
Posted: May 5th, 2017, 8:50 am
by g36
yep thats where it is on my 405 i also have a breaker in the main electrical panel for it
Posted: May 5th, 2017, 9:56 am
by dsolo
So I thought that was the waste tank monitor. OK thanks.
Posted: May 5th, 2017, 12:39 pm
by g36
The waste monitor tank watch is the 3 or 4 lights panel the water monitor is a at leat oem round guage in the same vicinity . I almost hesitate to say after the inverter
Take a look at this pic the water guage us on the far right below the counter top by the head
https://www.google.com/search?q=carver+ ... VrXRnwaCYM:
Posted: May 5th, 2017, 3:21 pm
by mjk1040
Hmm! On the 355 model it's in the galley, right of the stove, wonder why the put it back there on the 405's?
Posted: May 5th, 2017, 4:23 pm
by dsolo
Thanks to all. I will check it out this weekend. I plan on sanitizing the water system, per the method I read here, and using the water from the tank exclusively. The water monitor will be a valuable tool.
Posted: May 13th, 2017, 11:26 pm
by dsolo
Well found the meter right where g36 stated. Unfortunately it is not registering the tank level. It show's empty and the tank is full. Today while working on another problem I noticed alot of crosion on the wire terminals at the tank. I will clean them to see if it corrects the problem??
Posted: May 14th, 2017, 6:00 pm
dsolo wrote:Qr Bbpost Well found the meter right where g36 stated. Unfortunately it is not registering the tank level. It show's empty and the tank is full. Today while working on another problem I noticed alot of crosion on the wire terminals at the tank. I will clean them to see if it corrects the problem??
Have a close look at the terminals on the tank, see if there are two small adjusting screws on the plate, if so then you can adjust the tank gage reading with those..full and mt..instructions would be in owners manual....I know ours has that, but have a look.......
Posted: June 7th, 2017, 8:21 am
by dsolo
Following up on this post. Found the terminals heavily corroded. Scrapped and cleaned with contact cleaner. Adjusted the two pots back and forth. Had no effect on meter. Measured+12 vdc on power terminal and +8 vdc on other terminal. Adjusting pots did not vary voltage (+8vdc)
Does any know the mfg'r of this unit? Thanks
