Page 1 of 2
1977 Carver Santa Cruz Hull Question
Posted: May 29th, 2017, 4:20 pm
by USMCShellback
Hi Folks,
First post here apart from my intro. Here is the story that leads to the question. I was out at the Carver the other day getting the motor ready. Changed plugs, wires, oil, oil filter. There is a factory battery tray built into the port stern. Previous owner (I have owned about a year) moved the starter battery over to starboard stern partly resting on a 1x4 piece of wood, and partly resting on the fiberglass. I don't know why he did this, I think it was to accommodate starter wire replacement where he possibly got wires too short. This appears 1x4 to have kept the battery somewhat level. I decided to move the starter battery back to its intended home in the tray which appears to be able to hold about 3 batteries. I have two batteries, starter and deep cycle. With the battery back in the tray I hopped back over to complete the plug and wire swap. Directly where the starter battery was sitting my foot detected a somewhat soft spot in the fiberglass. This spot is about the size of the battery (what a surprise!). It does not flex to form a bubble shape, but when I put weight on it (gently once I detected it) it will push in a bit. My theory is that the previous owner had the battery in that place long enough to bounce around and affect the rigidity of the fiberglass over time. Previous owner had it for 15-20 years. I'm also aware that it could be a void in the glass, but don't think so. So here is my question:
Being that this spot is strong enough to hold shape while in the water (only flexes when I put pressure on it and I am a big guy), would this cause any of you concern to pull the boat? I'm a new owner and still learning.
I have attached a hasty drawing to show the exact area.
Re: 1977 Carver Santa Cruz Hull Question
Posted: May 29th, 2017, 6:07 pm
by waybomb
I think Carvers at the time had balsa coring below the water line.
You <may> have a wet core in that area.
Maybe somebody that knows for sure will chime in.
Posted: May 30th, 2017, 12:45 am
by USMCShellback
waybomb wrote:Qr Bbpost I think Carvers at the time had balsa coring below the water line.
From all my research I believe balsa core is correct. Concerning wet balsa below the water line, Ive read everything from "it can be fixed by a good glass layer" to "get a surveyor to come condemn it". Any info from anyone who has dealt with this would be awesome.
Posted: May 30th, 2017, 6:59 am
Until you get a surveyor or a good fiberglass tech to assess it, you won't know if the problem is widespread or limited to a localized area that can be repaired at a reasonable cost. If this is a wet core, you want to stop it from spreading as soon as possible before it turns into an unreasonable repair if it hasn't already.
Posted: May 30th, 2017, 10:34 am
by USMCShellback
Viper wrote:Qr Bbpost Until you get a surveyor or a good fiberglass tech to assess it, you won't know if the problem is widespread or limited to a localized area that can be repaired at a reasonable cost. If this is a wet core, you want to stop it from spreading as soon as possible before it turns into an unreasonable repair if it hasn't already.
I did get in touch with a Surveyor, he said not to even bother having it surveyed as he would only say "Yup, its a weak spot, take her to a Glass shop!" I appreciate his honesty!
I am now looking for a reputable repair shop in the area. The soft spot is not large but I recognize that doesnt signify the limit of damage, so once I find someone to get her to I will update here. The search is on, my wallet already feels lighter!
Posted: September 4th, 2017, 4:02 pm
by Big dog
I've got the same boat I'm thinking. This isn't about the soft spot but how yours run in the water. Mine wants to lean one way or the other. I use the tabs trying to correct the problem but the faster I go the more it leans. I've got a 350 with a bravo 2 drive. Just wondering???? Thanks Big Dog
Posted: July 16th, 2018, 1:32 pm
by USMCShellback
Big dog wrote:Qr Bbpost I've got the same boat I'm thinking. This isn't about the soft spot but how yours run in the water. Mine wants to lean one way or the other. I use the tabs trying to correct the problem but the faster I go the more it leans. I've got a 350 with a bravo 2 drive. Just wondering???? Thanks Big Dog
Hey Big Dog, sorry for the (very) late reply. Sounds like your prop and boat weight distribution may be rolling you while on plane. Also take into mind where folks are seated if you have visitors, and tell them not to move about while you are underway that can make you list if on plane. Mine is not in a lake where I can get it on plane and keep it there for any amount of time so I usually cruise at about 2k rpm or putt to where I'm going. The only time I've been rocked one way or another was when a speed demon flew by me and I had to deal with the wake he blasted on me. Ive been seeing more and more of these blown v8 speedboats ripping around and don't really care for them. I will say that turning against the prop is noticeably harder than with the prop. I don't have power steering so I sometimes have to muscle it a bit. Ill be pulling her out of the water later this year for some work and a little bit of resto-modding.
All that said, the gentleman that I bought the boat from had her balls to the walls once in order to get away from a tornado and he said that was the one and only time he ever ran her like that. He said quite frankly it scared the sh*t out of him and he would never do it again. He didn't elaborate on it any more than that.
Posted: July 16th, 2018, 3:13 pm
by Big dog
I'm getting better with the trim tabs. I can run 3500rpm and it isn't too Bad unless people start moving around. I've got to keep the bow in air or it will start cutting
Posted: July 20th, 2018, 5:27 pm
by SRVTRIBUTE
Just bought an 86 Santa Cruz. Do they all have a cable from upper to lower station?????
Posted: August 1st, 2018, 7:24 pm
by Msteph9834
SRVTRIBUTE wrote:Qr Bbpost Just bought an 86 Santa Cruz. Do they all have a cable from upper to lower station?????
I have a 1974 Santa Cruz, and on mine, the steering cable from the upper helm runs down into the steering gear box of the lower helm, then out to the stern drive with one cable. So yes, they are connected in the lower steering gear box.
