porthole screening
Posted: August 13th, 2017, 5:18 pm
by Scienceguy
Hi,
Does anyone know what glue material Carver used to hold the rubber gasket and screen into the porthole?
Re: porthole screening
Posted: October 2nd, 2017, 12:00 pm
by cpoint
did anyone respond to this? One of my screen is damaged, took it apart and saw it was glued also. Trying to figure out what type of adhesive I should use.
Posted: October 3rd, 2017, 7:10 am
Sikaflex makes a 295 UV product which is a UV resistant adhesive sealant. I wouldn't use a silicone based product.
Posted: October 3rd, 2017, 10:06 am
by cpoint
Viper wrote:QR_BBPOST Sikaflex makes a 295 UV product which is a UV resistant adhesive sealant
Thanks Viper. Looks like they don't have a small batch. I only need it for one port hole. I'll check to see if I can use this for other purposes on the deck. I do need to reseal some parts, if this works for that then it is worth getting the large one.
Posted: October 3rd, 2017, 5:30 pm
The small tube of regular Sikaflex will work too, it just won't have the UV inhibitor. 3M 4200 will work too.
Posted: October 29th, 2017, 9:01 pm
by cpoint
got it all fixed up. Thanks viper. Looks better than original. Since I have extra screen, maybe I should replace all :)
Posted: October 30th, 2017, 7:00 am
If you got the 10oz UV tube for the caulking gun, do all the screens now because the product in the tube will start going hard pretty quick after it's opened and you'll just end up having to buy another one to do the rest.
Posted: May 29th, 2019, 3:57 pm
by michelml54
Scienceguy wrote:QR_BBPOST Hi,
question: can you tell me what was the procedure you
question : what is the procedure to remove the old screen . Ihave a 325 carver and your screen looks the same and i do not know how to start to remove it
