Fresh Water System Pump
- amanphoto
- Has thanked: 3 times
- Been thanked: 12 times
I want something super quiet and powerful.
- Has thanked: 455 times
- Been thanked: 1671 times
Re: Fresh Water System Pump
- amanphoto
- Been thanked: 1043 times
However, a few years went by and the electronics failed. Out of warranty and no recourse but to buy a new pump (even though the actual motor and pump sections were just fine). I'm back to the standard type with pressure switch. Years ago I did add an accumulator tank to the system. That was probably the best upgrade I made to the potable water, other than replacing all the lines. The pressure is much more consistent after I made that change.
- Has thanked: 579 times
- Been thanked: 1210 times
amanphoto wrote:Source of the post I would like to replace my fresh water's holding tank pump with a new pump. My current pump works fine, but it is making some noise and I would like to replace it. I looked and there are millions of pumps out there. What is the best pump to get?
On thing I have noticed with ours.....when the screen on the intake side of the pump starts to get restricted, the pump gets noisy, clean screen and all is quiet again .....you probably know this but thought I would mention it just in case.......... ........
- SanJuanDreamer
- Has thanked: 1 time
- Been thanked: 21 times
I would like to mention, removing the pump you have and searching for a exact match replacement...saves time.
- Has thanked: 324 times
- Been thanked: 595 times
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
- amanphoto
Users browsing this forum: Chiefguns, Google Adsense [Bot] and 91 guests
