Crack in the motor block
- jipatton
- Lyndon670
- Has thanked: 124 times
- Been thanked: 140 times
Re: Crack in the motor block
The other question you have to consider is - what is your investment in this boat to date and what is your boat worth? You are probably looking at $3500 for a replacement motor, probably $1000-1500 to do the swap, maybe another $500 for misc items.
2000 Carver 506
FOXY JOE
Volvo 7.4TAMD
Queens Cove Marina
Georgian Bay, Ontario
- Has thanked: 455 times
- Been thanked: 1671 times
- MakinTime
- Vessel Info: Carver 3607 MakinTIme
Glastron MX175 MakinTimeToo - Has thanked: 52 times
- Been thanked: 31 times
Do you know why the block is cracked, was it due to freezing? If not, you need to find out what caused it to crack or you may be introducing a new block into a preexisting problem that might cause it to fail prematurely. If this happens, the supplier won't honour the warranty.
- jipatton
My total investment into this so far is only $6,500 and I'm not sure what I could get out of it if I sold it as is. I've already replaced the trim motor and carb. I've looked at the Michigan Motorz website, but am not sure which engine is a suitable replacement.
As far as why it cracked, is there a good way to figure that out?
jipatton wrote:Source of the post......I've looked at the Michigan Motorz website, but am not sure which engine is a suitable replacement.....
Give them a call, they should be able to help with that. At the very least, it'll give you an idea of the cost and how it compares to what you're marina/mechanic charges for the same thing. Something to consider is that if you buy the engine and have someone else install it, if the engine fails under warranty, you'll have to deal with the supplier. Depending on what caused the failure, the supplier may point the finger at the installer and the installer will point the finger at the re-builder, and you're stuck in the middle trying to get a resolution. Even if it's a supplier problem, the mechanic will charge you for follow-ups. The supplier will likely not compensate you for the labour. If you get the mechanic or marina to supply the motor and it fails, it's all on them to make good at their expense. It may cost a little more but worth it in the end if something goes wrong.
jipatton wrote:Source of the post.....As far as why it cracked, is there a good way to figure that out?
Your mechanic should be able to determine that. Depends on where the crack is. Is it raw water cooled or fresh water cooled (coolant)? Is this fresh water or salt water application? Are you in an area that requires winterizing? If so, that's the most likely reason. It may have been neglected or not done properly, and if the crack is a big smile on the side of the block, it froze.
I recommend adding your location to your profile, it'll tell us a lot about the environment you're in and help when answering questions.
- mjk1040
- Been thanked: 242 times
Users browsing this forum: No registered users and 69 guests
