Plumbing, Alternative 15mm Quick Disconnect Fittings
Posted: May 28th, 2018, 6:58 am
by Midnightsun
These fittings have always been a pita to get a hold of. Usually out of stock, special order not to mention expensive. Came across this at Home Depot, yes it says 1/2" however this is designed for an irrigation system which is not your standard 1/2" exterior dimension. I measured, tried, tested and can confirm it is interchangeable with 15mm boat stuff. Shelves are full and dirt cheap. No way can you get 50' of 15mm water line for $20 CDN? more like 5'. Its rather easy to disassemble as there are built in tabs to push back and release. Finally a cheap, easy to obtain alternative. Disregard the 3/4" stuff in the link, see here
https://www.homedepot.ca/en/home/search ... q=blu-lock
Re: Plumbing, Alternative 15mm Quick Disconnect Fittings
Posted: May 28th, 2018, 7:50 am
Hans....do you know who is the original maker of the quick disconnect oem fittings on our boats.....I have a couple at the water tank that are connected and disconnected a lot and are beginning to be a problem, do you think those sprinkler ones can be used with the 1/2" oem water lines on the boat....thanks for the info...
Posted: May 28th, 2018, 7:57 am
by Midnightsun
Are you sure your lines in your boat are 1/2"? Reason I ask is all my 3 previous boats (Bayliners) and my present Carver use 15mm. I do know some boats have 1/2" though. Look closely at any water line, should be printed on it.
Not 100% sure but think it is Sea Tech. I have purchased these in the past for my Carver and they look identical. I do know Defender carries them.
http://www.seatechinc.com/Products/Metr ... and_Tubing
Posted: May 28th, 2018, 8:16 am
Actually I don't know what size they are, will have to find the stamping , just haven't gone looking for it, it could be the 15mm you talk about, will check it today, have to check the fittings at the hot water tank anyway ( same every year ).... your post tweaked the ... now that is something else I can finally repair response.....
Posted: May 28th, 2018, 8:32 am
bud37 wrote:Qr Bbpost.....do you know who is the original maker of the quick disconnect oem fittings on our boats......
They'll be either SeaTech or Whale. Both have 15mm and 1/2" fittings as well as adapters to go from one size to the other.
bud37 wrote:Qr Bbpost .....I have a couple at the water tank that are connected and disconnected a lot and are beginning to be a problem......
Sometimes it's not the fittings but the line itself. Every time you connect and disconnect it abrades the line in the area that gets inserted into the fitting, take a close look. If that's the cause, cutting 3/4" off the end solves the problem. If it still leaks after that, then replace the fitting.
Are the lines red and blue?
Posted: May 28th, 2018, 8:51 am
Yes they are........I have been clipping them already, they are getting too short..
....and I just get the impression the fittings are getting to the end of life as well.....hopefully when I check today the drip will have stopped for this year..
Sorry for the hijack Hans...
