Page 1 of 2
Shower Faucet
Posted: May 29th, 2018, 9:02 am
by CaptBob
I have a leak. Don't like leaks. This one is in the shower faucet in the head. (yes, a dreaded wet head! now even wetter!)
Boat 04 360SS, the single lever faucet is leaking out of the single lever. I suspect there is a cartridge in there, much like a conventional faucet, but then again... I know it's a boat. Quick search has yielded no replacements, as the lines are on 6 inch centers, and the RV market seems to like 4 inch centers. I haven't figured out how to remove the handle, seems to be a small emblem, (with the hot/cold sign on it) that if removed would allow me access, however, I suspect that will destroy the little emblem. Not entirely against that, but first trying to do no harm.
Anybody been inside their faucet?
Re: Shower Faucet
Posted: May 29th, 2018, 9:06 am
by buster53
There's a very good chance that what you are looking for can be found at your local hardware. Don't limit yourself to RV-Marine stores.
Re: Shower Faucet
Posted: May 29th, 2018, 10:01 am
Pictures would probably help.
Even if you can't find the entire cartidge, a good hardware store would have various O-rings that could serve as replacements to the ones on your existing unit if you can figure out how to get it apart.
Re: Shower Faucet
Posted: May 29th, 2018, 11:34 am
Have a look real close look to the emblem you speak of......is there is a small slot for a screwdriver to pry off, like the ones at home... :beergood:
Re: Shower Faucet
Posted: May 30th, 2018, 7:11 am
by CaptBob
bud37 wrote:Qr Bbpost Have a look real close look to the emblem you speak of......is there is a small slot for a screwdriver to pry off, like the ones at home... :beergood:
There is gonna be one shortly! :-D
Ill get some pics the next day or so, I'm hoping for a "normal" cartridge solution.
Re: Shower Faucet
Posted: May 30th, 2018, 7:22 am
by Midnightsun
Re: Shower Faucet
Posted: June 6th, 2018, 11:13 am
by Antapostol
Any luck?
I am having the same problem it need to replace my fixture on a 1990 36 aft cabin. Cannot find an access panel to get behind the shower wall so I can remove the old fixture. Does anyone know how to access the backside of the shower wall to remove the shower fixture?
Re: Shower Faucet
Posted: June 7th, 2018, 8:18 am
by CaptBob
No resolve on this one yet. The Admiral discovered that if the valve is left "parked" in the cold position, it does not leak. So I am ashamed to admit, that project went to the back of the line.
This is my guy in question. That is the emblem that will soon suffer. :-O
Re: Shower Faucet
Posted: June 7th, 2018, 10:09 am
That emblem is a plug with a allen screw hiding underneath. Pop it out carefully and don't let it fall down the drain.
Re: Shower Faucet
Posted: June 7th, 2018, 10:12 am
km1125 wrote:Qr Bbpost That emblem is a plug with a allen screw hiding underneath. Pop it out carefully and don't let it fall down the drain.
And whoever mounted that to the surface should be smacked upside the head a few times! There should be a couple chrome-plated sleeves covering the piping down to the surface and the nuts UNDERNEATH the surface!
