Fuel consumption differential
Crowbar
Vessel Info: 1987 Carver Voyager- twin 230 hp gas
Post by Crowbar »
1987 28 ft Voyager. Twin 230 hp gas. 1580 hrs. My port engine burns between 1/2 and 3/4 gal./hr more than stb. engine. Is this excessive or sort of normal?
throwback2
and a few other water toys
Has thanked: 8 times
Been thanked: 23 times
Re: Fuel consumption differential
Post by throwback2 »
I have same boat and power.Both engines burn about the same. There's a lot of things that could cause this. Props could be a little different or slightly damaged,dirty flame arrestors,tune up needed,to name a few.
Check your chokes and make sure they are completely opening when the engine is warm. I had the choke thermostat go bad on my stbd engine and it would stay 1/2 way closed when the engine was warm. Still ran good, but used noticeably more fuel.
Could I ask, how are you measuring this fuel use ?
Crowbar
Post by Crowbar »
Thanks for the tips. I'm measuring when I fill the tanks. Typically, the stb will take 30 gal and the port will take 38-40gal
amanphoto
Has thanked: 3 times
Been thanked: 12 times
Post by amanphoto »
Check your propeller shaft drag. Do both propeller shafts have the same resistance when you manually turn them by hand (transmissions in neutral)?
Post by tomschauer »
if they are both tuned well, and your running gear is in good shape, it could be as simple as a sync problem. You would be surprised wahy a couple hundred RPM's will do.
If you don't have a sync, try pushing the starboard up a couple hundred rpm as read on the tach and see if it balances out.
