Dip stick stuck halfway
Allicatz
Vessel Info: 38 carver santego 1995
Postby Allicatz » August 29th, 2018, 8:34 pm
Carver 38 santego 1995 crusader engines
Starboard engine Dipstick will only go halfway down.Tried twisting turning jamming and forcing will not go down. What can I do? Going crazy please help!
Thank you
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 474 times
Been thanked: 201 times
Re: Dip stick stuck halfway
Postby pepmyster » August 29th, 2018, 8:53 pm
Hope the end is not bent? Turn the dip stick 180 degrees, then it should go in. Hope this helps, Do not force the dip stick at all. And welcome!!!!!!
Has thanked: 579 times
Been thanked: 1210 times
Postby bud37 » August 29th, 2018, 9:19 pm
Welcome to the forum....Im with pep....if it came out easy then it will go back in...take your time, check out how it works on the other engine.....compare the sticks, make sure you got the whole thing out.
Users browsing this forum: No registered users and 130 guests
