Well unfortunately I started the trip yesterday and the starboard engine would not increase above 3000 rpms. Generator started making a clanking noise which was a rocker arm that needed to be secured back down.
I never got out of the Galveston Bay after filling up with fuel. New plug wires and a new IAC Valve but that did not help. I am wondering if (you guessed it) trash from the tanks clogged up a fuel injector or two after filling the tanks.
Engine seems to be fine without a load, fuel pressure straight from the fuel pump is running 40-42 and 32-34 should be sufficient. Remember I replaced the fuel pumps and filters as well as the fuel regulator.
These engines are nothing more than standard Chevy 454 3500 series truck engines I learned yesterday.
We are replacing the distributor this morning with a complete assembly because it was replaced as piece set recently.
If nothing else at least the generator is purring and I didnt get stuck in the ditch. I shall see how today goes.
Engine Issues
- Serendipity
- Vessel Info: 1998 Carver 405
- Has thanked: 234 times
- Been thanked: 37 times
- waybomb
- CYO Moderator
- Been thanked: 492 times
Re: NEW INSTAGRAM ACCOUNT CARVERYACHTOWNERS
Bummer. Hope you figure it out in short order.
But Crusaders are not exactly just a standard 454. Yes, the base engine was a 454, but much of the internals have been changed. Please do not use automotive replacement parts. You could go "boom".
- Serendipity
Very good information Waybomb and thanks on the Crusader knowledge.
I cannot start to tell ya how much of a disaster yesterday was, but it can always be worse.
After replacing all 8 injectors on the starboard engine, the boat ran 25-27 mph full throttle at test. Just need to replace the injectors on the port engine at some point now. Engines ran fine so far at 3400 rpms at 18 mph average for 28 gallons burn per hour. I am filling up the tanks this morning. Any old fuel should pretty much be gone at this point.
So here I sit in Intercoastal City, no mechanic and a broken water impeller housing. Nothing in sight for over a 100 miles I am told and no parts. The blessing here is I called my local marina and they had a couple housings in stock and waited until after 5 for my wife to pick them up yesterday.
So my wife and daughter are bringing them to me 5 hours away. I am only going to install the broken housing currently and keep the other for a backup.
My question is guys, I had to come 40 miles yesterday on 1 engine. Started off at 10 mph and the engine was smoking, so I reduced the speed to 8 mph and the smoke pretty much stopped. So I am going to add oil and a bottle of ring restore my wife is bringing me to this engine, as well as to the other engine.
So the engine alarm went off after the housing broke. I shut the engine down immediately and ran below. Water was coming in, so I shut the seacock off. New bilges have done an excellent job of clearing all water inside the hull.
So after installing the housing and I appreciate any information you have that might make this install go quicker as I am doing it. I am thankful for the engine room but at 6'4 it is still going to be cramped.
Start up procedure the same? Let engines idle for 10 minutes or so?
Although the engines only have 300 hours on them, I see a replacement in their near future. Thanks for your advice.
The "smoke" was most likely just steam due to lack of cooling water. Don't add anything until you check the oil level. I personally would stay away from the ring restorer no matter what.
You should move this post to engines and maintenance.
- Serendipity
Tom
Not sure how to move this post to engines, maybe Bryce can.
It could have been steam. Not seeing your post and being a 25 year veteran service manger. I have had success with ring restore, so I had my wife pick up 2 bottles on the way to bring me parts.
After a few hours of running the port engine, I can only say the steam or smoke went away. I mean I am hopeful they last a summer or two but I bought the boat thinking the engines would need replacing at some point.
I put 45 hours on the engines on my trip back and they had 365 when I purchased the boat. I got 4400 rpms and 25 mph in the Gulf or off the coast of Mississippi 2 miles from the end of my trip. I am impressed for a boat this size and that is all I need to keep me happy.
