Carver Mariner 350 Bed mattress issues
Posted: September 24th, 2018, 10:37 am
by amanphoto
So here is the problem. The bed in my 1999 Carver Mariner 350 sucks - well, the mattress sucks. The shape and position against the wall sucks too, but more about that latter. The block of foam that came as the stock bed is very firm and we wake up with a sore back. To help solve this issue, I put a 3" queen sized memory foam topper on the bed. It's a little better but it's still kind of firm and as you sink into it all night, you back hurts in the morning. The queen sized memory foam is unruly, to big and overhangs the bed. So, I've decided to add another 3" of memory foam, full size this time, to help soften things up even more. Now the bed is a little hard to get into being even higher off the ground. In addition to being to tall, the full sized memory foam is to narrow for the stock bed.
I have not mentioned the large wedge shaped space at the top bed, between the mattress and the chain locker. The mattress is flush to the wall on the starboard side and is about 12" away on the port side. There is a shallow fiberglass wall (hump) that hold the mattress in place but is large enough to loose some pillows in at night. We sleep with our heads at the bow and end up stuffing some pillows in there.
I'm out of my mind....
The plan is to make a new mattress over the winter. My questions are as fallows...
1. Is there a minimum foam thickness or foam layer formula for building a foam mattress? For example so many inches of foam #, then so many inches of foam #, then...
2. Do I make the mattress go over the fiberglass hump at the top of the bed? If I do, I'm going to need custom made sheets.
3. It's a custom shaped bed. The starboard top corner is rounded to I'm going to have to trim the corner off. Also the starboard edge is tapered. The thicker the bed is, the more space (gap) there is in the starboard side.
What have you done to make a comfy nights sleep? Any make a custom mattress for their Carver? I don't want to put a sock twin mattress in there. It will not match the contour of the boat.
Re: Carver Mariner 350 Bed mattress issues
Posted: September 24th, 2018, 9:56 pm
by tomschauer
We bought a 6" queen latex mattress from the foam factory and cut it to fit our odd sized bed. Very happy, sleeping well.
Posted: September 24th, 2018, 10:49 pm
by RGrew176
Not quite the same situation as you. When I bought my 3007 Aft Cabin in 2015 the first thing I noticed was how hard the "mattress" in the aft cabin was. Like yours it was difficult almost impossible to get a good nights sleep on. Like you I purchased a 1 1/2" memory foam mattress topper. On top of that I took a medium thickness comforter folded it in half and I placed that on top of the memory foam. Then the usual mattress cover and sheets. Now I sleep quite well. It is a lot more comfortable than it was with just the plain mattress.
Posted: September 25th, 2018, 8:08 pm
by chpsk8
Do you have a company called Mattress Factory near you? They custom make mattresses for a reasonable price.
We've used a 3" foam topper I got off amazon with good luck. Electric knife to shape it. Next one I'm going to mattress factory and getting exactly what I want.
Posted: September 26th, 2018, 11:09 am
We have a place local called the Foam Factory. You can make a pattern with some heavy paper and take it to them. They have several varieties of foam and will custom make a mattress of different densities and thicknesses of foam depending on what you're looking for. Did mine about 12 years ago but I only went with a single density foam block and it's worked for us.
Posted: September 26th, 2018, 11:40 am
by Midnightsun
Posted: September 29th, 2018, 3:54 pm
by amanphoto
This is the top of the bed. The originall mattress is rounded. The toppers are back about 6” back from that. There is also the plastic bump that sticks out.
Posted: November 18th, 2018, 11:06 pm
by Bentone23
I sent my mattress off to be copied 2 weeks ago. Mine is too soft and my shoulder and hip rest on the hard fiberglass all night. Very painful. My aft cabin mattress is an odd size too. The mattress company should be done next week. They charged me $600 which I thought was reasonable for a custom mattress.
