Page 1 of 2
What Is This Thing???
Posted: October 29th, 2018, 5:18 pm
by fleck05
I have a 1983 Aft Cabin 3607 and have been wondering about a wood square on the port side of my hull (pictured). The wood is rotting apart but since whatever used to be attached has been cut I never really tried to figure out what it is... but I am curious. Maybe something to do with grounding at some point? Thanks.
Re: What Is This Thing???
Posted: October 29th, 2018, 5:33 pm
by Midnightsun
My guess is an old transducer since there is what looks like a wire coming out of it.
Posted: October 29th, 2018, 5:59 pm
Looks like a few old ones down there, or is that the same one in both pics.....what are you thinking to do ? Maybe on the list next haulout, bottom job?
Posted: October 29th, 2018, 7:55 pm
Ya looks like an old ducer. Before it starts leaking, remove it, remove the wood backer plate, and have a fiberglass tech patch the hole properly or use the same hole to install a new ducer for a new sounder, or seacock for a future upgrade, etc.
Posted: October 29th, 2018, 8:17 pm
by buster53
Is it possible that is a transducer that shoots thru the hull and there is no hole there?
Posted: October 29th, 2018, 8:42 pm
It looks like there is a tightening nut on a threaded shaft there which shoot-thru-the-hull types don't have.
Posted: October 29th, 2018, 9:27 pm
I would say old transducer too.
I have an 83 3607 as well. Do you have a generator? Is that silver thing the muffler for it?
Posted: October 29th, 2018, 11:05 pm
by RGrew176
Already answered but that is most likely an older in hull transducer. Looks almost identical to the in hull transducer I currently have on my 3007.
Posted: November 2nd, 2018, 2:33 pm
by fleck05
Thank you for the answers.
"Looks like a few old ones down there, or is that the same one in both pics.....what are you thinking to do ? Maybe on the list next haulout, bottom job?"
Just the one, I was showing its location. I need to haulout sometime in the next few months and replace the exhaust pipe (tube?)... exhaust thing with date on it. The starboard side was replaced, but the port was not and I'm getting drips coming in - the date on that tube is a lot older than the starboard one.
"Before it starts leaking, remove it, remove the wood backer plate, and have a fiberglass tech patch the hole properly"
This was a curiosity... when the wood rots through can it leak?
"It looks like there is a tightening nut on a threaded shaft there which shoot-thru-the-hull types don't have."
So maybe it won't leak if the wood rots?
"I have an 83 3607 as well. Do you have a generator? Is that silver thing the muffler for it?"
Yes - that is the muffler for the generator.
Thanks for the info - your answers have given me a great place to start researching. The boat is only a few months old to me and I'm about to dive it and clean it for the first time. If it goes through maybe I'll be able to tell from underneath. I'll follow up on this thread if I find something out that's interesting.
Thanks again.
Posted: November 2nd, 2018, 5:05 pm
fleck05 wrote:QR_BBPOST.... when the wood rots through can it leak?
So maybe it won't leak if the wood rots?.....
The nut is what's fastening the ducer to the hull. When a backer plate rots, the whole assembly becomes loose and allows movement. Eventually the movement causes the seal to fail and leak.
