The thrill of discovery!
Glendinning Engine Synchronizer
- Tomb266
- Vessel Info: 1991 Carver 430 cockpit MY
- Has thanked: 5 times
- Been thanked: 4 times
On my 1991 Carver 430 cockpit MY the surveyor noted a line item for the engine synchronizer. I have never used it, but while tracking down a blow fuse in the engine compartment I was directly under the control unit for the synchronizer and discovered that the previous owner had disconnected the linages to the throttle cables. I plan to check the system out while in dry dock, but I wonder if I shouldn't just remove it all together. There is a gauge on the helm that seems to give a visual indication when the engines are balanced so, I question the need for the synchronizer. Can anyone share their experience or thoughts on this?
- jmm48m60
- Vessel Info: 2002, carver 356 aft cabin, Crusader engs, hurth transmissions
BOAT NAME 'TANKRR' - Location: virginia
- Has thanked: 2 times
Re: Glendinning Engine Synchronizer
I have a 2002 Carver 356 aft cabin, with Crusader engines. Boat has a sync gauge which at a speed ex: 2500 rpm on both tachometers the sync gauge indicates much more starboard … any thoughts
