Inverter
- A Lee
- Vessel Info: 2005 56' Voyger
- Been thanked: 3 times
Inverter
The charge side of inverter is not operative while on generator power. The charge side works while on shore power. The only obvious difference is that the shore power is through a power isolator. I am wondering if the inverter is sensitive to the exact voltage being supplied? Any thoughts/advice would be appreciated.
- Been thanked: 654 times
Re: Inverter
Can you tell us what make and model you have that's giving you trouble?
Re: Inverter
first i would take meter and check for input voltage coming to the charles unit while the genset is running and also ac shore /boat selector switch and breaker in panel and also on the genset. i guess this has been working fine and now its not?
- A Lee
Re: Inverter
Will check the voltage-thanks; I did not experience this issue last season and first time to charge on gen this season.
