holding tank access 1990 2357 montego
senjen
Vessel Info: 1990 2357 Montego.
1986 28 Monte Carlo
1986 21' scarab 1
1980 30' Sedan Bridge
Has thanked: 3 times
Post by senjen »
can anyone tell me where the access point is for the sanitation holding tank is on a 1990 2357 Montego is? I need to inspect the tank but cant find a way to get to it. :banghead:
Been thanked: 285 times
Re: holding tank access 1990 2357 montego
Post by buster53 »
If you have carpeting you will probably need to pull it up to access bilge hatches
senjen wrote:QR_BBPOST can anyone tell me where the access point is for the sanitation holding tank is on a 1990 2357 Montego is? I need to inspect the tank but cant find a way to get to it. :banghead:
Is it possible you have the head with the attached tank, has a pump out hose connected to that.......I don't know just an idea as I think that was an option for some.....
senjen
1986 28 Monte Carlo
1986 21' scarab 1
Post by senjen »
no carpeting in the area tank location is on port side behind the head. just don't see any point to access the tank area. little hot down in my area right now so digging around in the bilge time is limited. I haven't seen one in there as of yet. going out again today thinking now it might could be be in a area under the stairs. not much room for access there though but worth a look just saw your last post. no its definitely not attached
senjen
1986 28 Monte Carlo
1986 21' scarab 1
Post by senjen »
bud 37 boat came stock with a honey hole like you mention the manual pump head and holding tank was an option.
thanks
Post by buster53 »
Just remember, Carver is very creative in putting hatch’s in out of the way, hidden spots. Under carpet, under bed, under stairs, inside or behind cabinets...you really have to search
senjen
1986 28 Monte Carlo
1986 21' scarab 1
Post by senjen »
great call. talked to craver rep and he told me where to check. haven't made it back to slip to check it out but access is going to be to from port side of mid cabin under the mattress. would not have found it in a thousand years.
thanks again for your insight on hidden access points.
Post by buster53 »
Thanks senjen. I used to have a 3807 and we found a couple of bilge hatches in some really out of the way places that took some looking for.
We now have a 356 and we have at least 3 underneath the aft cabin carpet. Maybe more but we haven't pulled the entire carpet up yet.
