1987, 3607 sea cock locations
- RWS
- Vessel Info: 1987 3607 aft
- Has thanked: 28 times
looking for a little help to make sure I find all my sea cocks for winterizing . Our boat has electric heads, I assume there is a sea cock for each engine, the gen set, ac pump,sea water wash down and the 2 heads. Would that be 7 I need to find. Thank you in advance for helping. 1st year of boating and the help I have gotten here has be a God send.
Re: 1987, 3607 sea cock locations
Quick question....... RWS are you winterizing for leaving the boat in the water all winter or will it be in the parking lot on stands etc ? Seems that you are on the right track, just make sure to have a real good look around, you never know what has been done before you got the boat, make a labelled diagram of everything you find and where it was found.
You list sounds good, but some of those might be combined.
I have an older 3607 (83). There is an engine seacock just ahead of each engine. I have one other seacock that is for both heads, and it is in front of the port engine. That seacock also feeds my one HVAC unit. I don't have a generator nor a washdown.
- RWS
bud37 wrote:Qr Bbpost Quick question....... RWS are you winterizing for leaving the boat in the water all winter or will it be in the parking lot on stands etc ? Seems that you are on the right track, just make sure to have a real good look around, you never know what has been done before you got the boat, make a labelled diagram of everything you find and where it was found.
we are in east Tennessee , it will be staying in the water
