2000 carver 356 a/c-heat control unit on wall
- Gary Rose
- Vessel Info: 2000 356 carver aft
- Has thanked: 5 times
- Been thanked: 3 times
Anyone have any idea where to get the wall controller for the a/c-heater for a 2000 carver 356 ???
- DanM
- Vessel Info: Carver 396
- Been thanked: 35 times
Re: 2000 carver 356 a/c-heat control unit on wall
On my 356 it was supplied by the maker of the AC/Heat unit which is almost always the case. Don't rely on the build sheet if this is a used, new to you boat as it may have been replaced with a different model.
Dan
Carver 396
SugarSand Tango
Carver 396
SugarSand Tango
Pics would help to identify it, but if you look closely (might have to remove and look at the back) there should at least be a manufacturer name on it like Cruiseair or MarinAire.
Send these guys an email with information on the unit you need, they'll likely have it: http://www.themarineconnection.net/
You could also do a Google search, I'm sure all kinds of suppliers will pop up. Any marina that has access to ordering AC units should be able to order what you need as well. Or, look on Amazon or eBay.
Good luck.
Good luck.
