Manual pump beside gas tank on starboard side
Robby Robb Lewis
Vessel Info: 1986 26 ft Montego
Post by Robby Robb Lewis »
Hey guys and gals.
Can one of you tell me what the manual pump beside gas tank is for? It looks like it has a thru hull fitting.
Thx
1986 26' Montego :captain: Robby Robb
Craig_B
Vessel Info: 1988 Carver Santego 3067
Has thanked: 144 times
Been thanked: 13 times
Re: Manual pump beside gas tank on starboard side
Post by Craig_B »
WIthout a picture this is a complete guess but maybe a manual bilge pump?
Robby Robb Lewis
I thought same but the thru hull is in engine compartment. That would be no use in water. I will take pic tomorrow. Thx for helping.
Robby Robb Lewis
Can anybody tell me what this pump is used for?
That looks like a manual gulper pump. Could be used for a number of things but usually in an emergency to pump out the bilge. I've also seen them hooked up to holding tanks for overboard discharge.
Robby Robb Lewis wrote:QR_BBPOST Hey guys and gals.
Thx
Can you see what the other end is attached to, does it have arrows to indicate the flow direction thru the pump ? ?...I was thinking the same as Viper, maybe waste.
Robby Robb Lewis
Guys thx for responding. I cant see the other end but it does go through the hull in the engine department . Does look like a discharge of the fresh water tank or waste. Does your fresh water discharge have an electric pump? There is another electronic PAR pump in front of it. This exits out the side of the boat.
Robby Robb Lewis
Cant you use waste pump at sea? ( ten miles out) that means the electric is for waste and the manual pump for fresh water winterization. You all agree?
Robby Robb Lewis
Problem solved! It is a waste pump out. I crawled under and traced input. It amazing that the waste pump out would be under the boat while underway. I guess a seacock opens and closes it. I would like to thx all responses. Hopefully I can help you guys in future.
Capt Robby Robb
Robby Robb Lewis wrote:QR_BBPOST ....It amazing that the waste pump out would be under the boat while underway....
That's the normal location for waste discharge....through the bottom of the hull.
