Page 1 of 2
Manual pump beside gas tank on starboard side
Posted: April 25th, 2020, 6:20 pm
by Robby Robb Lewis
Hey guys and gals.
Can one of you tell me what the manual pump beside gas tank is for? It looks like it has a thru hull fitting.
Thx
Re: Manual pump beside gas tank on starboard side
Posted: April 25th, 2020, 6:25 pm
by Craig_B
WIthout a picture this is a complete guess but maybe a manual bilge pump?
Posted: April 25th, 2020, 6:27 pm
by Robby Robb Lewis
I thought same but the thru hull is in engine compartment. That would be no use in water. I will take pic tomorrow. Thx for helping.
Posted: May 24th, 2020, 10:15 pm
by Robby Robb Lewis
Can anybody tell me what this pump is used for?
Posted: May 25th, 2020, 7:01 am
That looks like a manual gulper pump. Could be used for a number of things but usually in an emergency to pump out the bilge. I've also seen them hooked up to holding tanks for overboard discharge.
Posted: May 25th, 2020, 8:05 am
Robby Robb Lewis wrote:QR_BBPOST Hey guys and gals.
Thx
Can you see what the other end is attached to, does it have arrows to indicate the flow direction thru the pump ? ?...I was thinking the same as Viper, maybe waste.
Posted: May 25th, 2020, 3:08 pm
by Robby Robb Lewis
Guys thx for responding. I cant see the other end but it does go through the hull in the engine department . Does look like a discharge of the fresh water tank or waste. Does your fresh water discharge have an electric pump? There is another electronic PAR pump in front of it. This exits out the side of the boat.
Posted: May 25th, 2020, 3:21 pm
by Robby Robb Lewis
Cant you use waste pump at sea? ( ten miles out) that means the electric is for waste and the manual pump for fresh water winterization. You all agree?
Posted: May 25th, 2020, 6:17 pm
by Robby Robb Lewis
Problem solved! It is a waste pump out. I crawled under and traced input. It amazing that the waste pump out would be under the boat while underway. I guess a seacock opens and closes it. I would like to thx all responses. Hopefully I can help you guys in future.
Capt Robby Robb
Posted: May 25th, 2020, 9:38 pm
That's the normal location for waste discharge....through the bottom of the hull.
